Tagged: 19.1, ANSYS Composite PrepPost, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantIn metric, density is already in mass/volume, but engineers using the British Inch system often are accustomed to using Weight Density. So for aluminum it is .1 lbf/in^3. Since this is not mass density, one needs to divide by gravity. So take .1/386.1 and you will have that number.
