June 6, 2022 at 9:58 am
FAQ
ParticipantThe stiffness matrix defined in Engineering Data should be a positive definite one.
Being positive definite means that the following expression must equal a positive number:
1.0 – NUXY**2*EX/EY – NUYZ**2*EY/EZ – NUXZ**2*EX/EZ – 2.0*NUXY*NUYZ*NUXZ*EX/EZ
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- Hyperelastic Simulations
