March 17, 2023 at 8:59 am
FAQParticipantThis can happen due to hiding/unhiding the bodies and not saving the current state in Solidworks. For example, your saved state had some bodies hidden in your assembly and now you make them visible (unhide) but do not save the assembly. After this, if you import the assembly in SpaceClaim, it will import it in last saved state – i.e. some bodies being hidden. To get the correct assembly in SpaceClaim, you may need to save the assembly in Solidworks and then import it in fresh SpaceClaim session.
