April 5, 2023 at 2:32 pm
FAQ
ParticipantIn a structural transient analysis, when we have damping, we see a phase lag due to the damping term (being proportional to velocity rather than displacement). In a transient FSI analysis, the situation is different – Fluent does not give Mechanical a damping matrix. Instead, Mechanical passes displacements to Fluent, which returns forces (pressures).
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
