Why PGVECTORS are not available in Mechanical under the User Defined Results for linked analysis systems?
June 6, 2022 at 9:58 am
FAQParticipantTo get this result item, insert a “Commands (APDL)” object under the analysis branch with the command “OUTRES,ALL,ALL”.
