Tagged: 19.2, CAD Imports, mechanical, solidworks, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantIn SolidWorks, under Equations panel, please check if the parameters are locked. When the parameters are exported to external file and linked with external file (such as *.txt), they are locked and can not be updated. The above issue can prevent the parameters in WB remain unchanged even after WB associative interface for SolidWorks runs fine.
