Why one is not able to see Isotropic Stress and strain limits in ACP pre even after defining yield strength & strain limit in engineering data?
Tagged: 17.2, ANSYS Composite PrepPost, General, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantPlease check for Ply type is defined to isotropic for isotropic material in engineering data.
