Tagged: 19.1, ANSYS Composite PrepPost, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThose are typically coming from upstream Mechanical. If one looks in Mechanical there will be some coordinate systems. One can not delete those.
