Why might a Modal analysis performed on unconstrained assembly not produce six rigid body modes with zero frequency?
January 25, 2023 at 7:34 am
FAQ
ParticipantIf penalty based contacts are used to tie the parts together, this could introduce artificial stiffness that can affect the free modes. In particular this could affect the three rotational modes. To avoid this try changing the contact formulation to MPC. This should result in six rigid body modes with zero frequency
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
