Why might a joint definition become invalidated and remote points scoping is lost (shows yellow mark) in Mechanical?
Tagged: 2021 R1, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantWhen joints are scoped to remote points you need beta feature turned ON. By turning beta option ON , You won’t see the invalid joint definition and yellow mark inside joint details while scoping to remote points. To turn ON beta feature in Workbench go to Tools Menu>>Options>>Appearance>>check box for Beta Feature.
