Why MAPDL gives error, ” Element xxxx has a radius/thickness ratio of xxxxxx. This violates assumption of shell element” even after turning off shape checking SHPP, OFF?
Tagged: 18, General, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantThe reason of this error seems caused by very warping elements. The shell element radius to thickness ratio check is not controlled via the SHPP command. This is a message that is not part of the element shape checking logic so the SHPP command will have no effect on its behavior. The workaround is to modify those shell elements until they meet the requirement or check the warping quality.
