June 5, 2023 at 7:05 am
FAQParticipantThis issue happens when the compatible graphics renderer is not available while working with SpaceClaim. By default, SpaceClaim uses Direct3D11 (or Direct3D9 in case of earlier is not available) renderer. If these renderers are also not available then you can use WARP to get the Graphics for geometry modelling. The above options are available under; File–>SpaceClaim Options–>Advanced–>Graphics–>Rendenrer
