Why is there a difference between the stress plots for PIPE18 (elastic) and PIPE60 (plastic) elements?
Tagged: 17, General, mechanical-apdl, modeling-and-meshing, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 462244.pdf
