Tagged: 19.2, materials, mechanical, Special Purpose, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe elastic foundation stiffness is pressure-per-deformation. For example, the surface area is A and foundation stiffness is K and deformation normal to the surface is X. The reaction (force , N) of the foundation is A*K*X.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
