Tagged: 19.2, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipant/CYCEXPAND does not affect the database. SENE from it is for the full model while SENE from “EXPAND,1, MODAL” is for only the base sector.
