Tagged: 19, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThe section view panel can carry a maximum of 6 views at a time. When the user defines more number of views, it is automatically disabled. In order to restore it, in Mechanical, Go to View> Windows> Section Planes. Once the Section Planes panel appears, the user may delete one or more planes to define new section planes.
