Tagged: 19.2, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantThe forces from NFORCE would be different depending on the element isolation method. For example, there are four elements attached to a single node. If you select all of them, the resultant force is zero.
