January 25, 2023 at 7:34 am
FAQ
ParticipantKeyword: missing mass, prestress, PSD Missing mass doesn’t support linear perturbation based on nonlinear structural analysis (e.g., large deflection, frictional contact…). Removing all nonliearity in static structural will enable missing mass work. If you would like to include nonlinear prestress, a workaround to account for truncated modes is to use residual vector. See solution #2042955 for example of residual vectors in PSD analysis
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
