Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
June 6, 2022 at 9:58 am
FAQParticipantThe 2 forms of damping are really different:
Structural damping enables you to incorporate hysteretic behavior due to internal material friction by specifying a coefficient on the stiffness matrix. In this type of damping, the damping force is proportional to the displacement rather than the velocity as in the other damping options (alpha and beta included).
Vicious damping in the air is much smaller than the damping due to internal material friction but historically only viscous damping was available and we used to put all damping into viscous damping.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
