Why in a Workbench, I can not see the option to enable the import line bodies in the ‘Geometry Cell’ properties?
Tagged: 18.1, CAD Imports, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThe option to enable the line bodies import in the Workbench is shown before attaching or importing the model into the ‘Geometry’ cell. To enable this option, add a new analysis system or Geometry component in the WB
