March 17, 2023 at 9:00 am
FAQParticipantWe can’t use the same guidelines about effective mass ratio for cyclic modal as we would with non-cyclic models. The effective mass won’t match for cases other than Harmonic Index=0. As per help document: For cyclic symmetric models, the participation factors are only provided for HI=0 and 1, and these values are multiplied by sqrt(N) and sqrt(N/2) to match a full 360 deg model. This is described In Section 4.1.7, please see section below: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/ans_cycsym/advcycmodalans.html
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
