Why don’t mode shape deformations for the first 3 rigid body modes translate along global x,y and z directions?
June 6, 2022 at 9:58 am
FAQ
ParticipantThere is no guarantee or restriction to require that the rigid-body modes are parallel to the global Cartesian coordinate system. Consequently, if the calculated rigid-body modes aren’t aligned with global Cartesian, they may look strange. What matters is only that the rigid-body modes (eigenvectors) are orthogonal to each other. Hence, there should be a linear combination of modes 1 through 6 to equate rigid-body translation along the global X direction, for example. Rigid-body motion has no unique solution. The basis taken is not orthogonal to the global CS doesn’t mean that it’s incorrect.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
