Why don’t ANSYS harmonic results match ABAQUS for a 6% damping value? If we use dmprat,.03 the results match.
April 5, 2023 at 2:33 pm
FAQParticipantMany codes use “Loss Tangent” to define damping. In Chapter 1 of the WB Mechanical Dynamics Training notes there is table of different damping specifications. Damping ratio is equal to (Loss Tangent) / 2. You can also see that in Theory Manual EQ 15-21. Damping input with TB,SDAMP (loss tangent) is multiplied by 1/OMEGA, damping input with MP,DMPR (damping ratio) is multiplied by 2/OMEGA. Note that in a harmonic analysis, damping ratio is not a constant ratio to critical. For a single mode it would be ratio to critical at resonance but become a smaller ratio to critical at lower frequencies and a higher ratio at higher frequencies. This effect isn’t very noticeable because the effect of damping decreases quickly away from resonance.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
