Why does the Topology Optimizer sometimes continue running after the convergence criteria on the objective function has been satisfied?
June 5, 2023 at 7:05 am
FAQParticipantBy design, the Topology Optimizer will continue until three consecutive iterations to meet the convergence criteria.
