Why does the Static analysis (actuator from workshop in RBD training ) with “Import Motion load” does not converge?
Tagged: 19, mechanical, Multibody, structural-dynamics, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantQuestion: I am doing a workshop on the rigid body dynamics. I am trying to use the RBD results on to a static analysis using “Export Motion Loads”. My static analysis can import all the loads needed, but the analysis won’t converge if I follow all the steps in the tutorial. Only if I add a fixed support, I can get covergence. Can you please tell me if the fixed support addition is needed or not. Workshop tutorial shows results even without any support. Answer: Try resolving static structural after turning on Weak springs (Mechanical >> Analysis Settings >> Solver Controls >> Weak Springs >> On )
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
