Why does the sign of the phase angle need to be reversed for correct Contour plots in Harmonic analysis ?
August 25, 2023 at 12:16 pm
FAQParticipantThe phase angle of a response is usually defined as positive for a phase lag because response tend to lag the force and this results in positive value for phase angles. Mathematically, a phase advance convention would be much better because a positive phase angle would rotate on the complex plane in the same sense as a rotation caused by a positive “wt”. A phase angle calculated directly from a complex algebra ( Ansys uses complex algebra in harmonic response analysis) dynamic solution will generally be a phase advance angle and will have to have sign reversed in order to convert to phase lag. This is explained well in Dynamics of Fixed Marine Structures Book by A. J. Adams and N. D. P. Barltrop.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
