Why does the ANSYS nCode DesignLife model fails after changing materials? Error: In matml(nCode material database): Dataset does not exist, or is an unsupported type.
Tagged: 18.1, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantThe error message is due to inconsistent Solver Method (Advanced Edit > Analysis Runs Run1 > AnaDef > SN or EN ENgine > Sn or ENMethod) and Material type (Edit Material Mapping).
