Why does specifying the default ratio=1.0 affect the new SYNCHRO results in ANSYS 11.0? It results in a general rotational force analysis being done instead of an unbalanced force.
March 17, 2023 at 9:00 am
FAQParticipantThe SYNCHRO command is unlike most ANSYS commands in that specifying the default is not the same as leaving the field blank. When any numerical value is specified for ratio: [SYNCHRO,RATIO] it is assumed that the specified force is to be applied as a normal rotational force and not an unbalance (F=omega^2 * Unb) [Ref: SYNCHRO command notes]
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
