Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantWhen the plastic strain is beyond the last data point of the KINH curve, it result in a zero stiffness. In that case NLAD can’t be used. You may here modify your material data definition.
