Why does MPLIST and TBLIST not show the Compressive Ultimate, Compressive Yield, Tensile Ultimate, and Tensile Yield material properties?
Tagged: 19.2, General, materials, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantThe Compressive Ultimate, Compressive Yield, Tensile Ultimate, and Tensile Yield material properties are not used in the solution of the model. They are only used after solving by the Stress Tool in calculation of Safety Factors, Safety Margins, and Stress Ratios. As such they are not passed to the solver which i confirmed by examining the ds.dat file. They are also not written to the rst file so there is no way to view them by any command. They are shown in the report under material data.
