Why does it take so long to compute the RPSD. It is taking 10 times as long as the PSD analysis itself.
March 17, 2023 at 9:00 am
FAQ
ParticipantTheory Manual Equation 19.14-1 is used in computing RPSD. The number of calculations involved is approximately proportional to modes**3 depending on the resolution set with STORE,PSD. For a large number of modes the number of calculations becomes very large. My suggestion is to reduce the resolution on the STORE,PSD command to STORE,PSD,3 or so. Then once the RPSD is computed integrate it; take the square root and compare it to the 1 sigma value in POST1 to ensure the accuracy of the RPSD curve. While speed is a major limitation of RPSD , it does allow the user flexibility in computing the RPSD of any dof, stress or force quantity after the solution is already done. In some software the user has to specify the desired result prior to solution.
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to include effect of bolt pretension in a modal analysis?
- Presentation on shock analysis using response spectrum and transient dynamics
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
