March 17, 2023 at 9:00 am
FAQParticipantIf the number of modes in the required range are more the combination takes large run times, for examples if there are 50 modes in required range, the possible number of combinations are 50C2 i.e.,1225 combinations. When we do the modal superposition by SRSS method, the lcoper operations needed are 50, whereas CQC and ROSE require 1225 operations, hence it takes large time
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
