Why does Fatigue Tool in a PSD in a random vibration analysis ask for turning on velocity calculation?
January 25, 2023 at 7:34 am
FAQ
ParticipantThe frequency-based fatigue depends on the statistical frequency that is the ratio of RMS velocity over RMS displacement. Be default, WB only writes the displacement solution into the database. This can be changed under Analysis SettingsOutput Controls.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
