Tagged: 19, materials, mechanical, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe “TB,DP” Drucker-Prager material is for legacy elements. It has many limitations, and it is not supported by current-technology elements. Please use “TB,EDP” (Extended Drucker-Prager) material instead. When you use TB,DP, since it is not supported by the current-technology elements, that input is ignored, so the material is treated as linear elastic only. For “TB,EDP”, the input coefficients are not the same as “TB,DP”. Please see the following memo for conversion of the older Drucker-Prager material to the Extended Drucker-Prager material: http://ansys.net/collection/1096
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
