Why does changing the Exposure Duration for a Random Vibration fatigue analysis using the Mechanical Fatigue Tool not affect the calculated Life?
Tagged: 19.2, fatigue, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe calculated life for random vibration fatigue is not affected by the exposure duration, because the Mechanical Fatigue Tool always reports the life in seconds, regardless of the specified exposure duration. The damage is reported as damage per exposure duration, but the life is reported in seconds. If you check the Details Window, you will see that the life is reported in seconds (unit is greyed out and cannot be changed). To calculate the fatigue life, the Mechanical Fatigue Tool takes the reciprocal of total damage, but it then multiplies that quantity by the specified Exposure Duration. The net effect is that Exposure Duration used in the damage calculation is canceled out in the life calculation. Note: This method is not consistent with the method used by ANSYS nCode DesignLife. DesignLife reports both the life and damage in terms of the exposure duration.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
