Why do I receive the following error when I try to export global mass matrix from the .FULL file in a full harmonic analysis? *** ERROR *** *DMA Command: This matrix (MASS) is not available in the file file.FULL.
April 5, 2023 at 2:31 pm
FAQParticipantIn a full harmonic analysis, we solve the equation [K_c]{u_c}={F_c}, where [K_c] is a combination of the stiffness/mass/damping matrices as defined by Eqn. 15-67 in this documentation link. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/ans_thry/thy_anproc4.html%23anpsolution So, the mass matrix is not explicitly written to the .FULL file. The work around is to use variational technology, which allows you to write the stiffness and the mass matrices to the .FULL file. You can do this from Analysis Settings > Variational Technology > Yes or just insert a command HROPT,VT.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
