Why do I not see the option to add layered sections in my Workbench Mechanical? Is it not supported by my license?
Tagged: 19.1, composites, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantQuestion: I’m trying to define a sandwich shell structure. From the help files it looks like I should be able to that with a layered section but when I right click on Geometry in the Ansys Mechanical tree that option is not available. How do I enable this feature? Answer: Please check the license you are using. (You can do this by looking at the top left of the Mechanical window.) This feature is not supported by the lowest level license which is “Mechanical Pro” license. Higher level licenses (Either “Mechanical Premium” or “Mechanical Enterprise” ) is needed to access Layered Shell composites feature. You can also verify this by taking a look at the ANSYS Capability Chart.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
