Why do hard copy contour plots (/SHOW,PNG or /SHOW,JPG) show only nine color bands when the screen displays more than nine?
Tagged: 7, apdl, General, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantEight color planes are required to obtain more than nine contours. The default is four color planes. The number of color planes can be modified using /SHOW (e.g., /SHOW,PNG, , ,8).
