Why do for some of the hyper-elastic problems show better convergence trend with unsymmetric Newton Rapshon (NROPT,UNSYM) solver ? Does Mixed u-P formulation result in unsymmetric stiffness matrix ?
March 17, 2023 at 9:00 am
FAQ
ParticipantMixed u-P element formulation itself doesn’t introduce unsymmetric stiffness matrix. The stress stiffening matrix is unsymmetric and pressure load stiffness matrix is also unsymmetric. Usually a procedure of symmetrizing the tangent stiffness matrix is invoked and then solved with symmetric Newton Rapshon (NROPT,FULL) solver. So when the contribution of stress stiffening and pressure load stiffness matrices are significant in resulting Consistent Tangent Stiffness Matrix for a problem, then NROPT,UNSYM shall lead to better convergence trend. But there is trade off. The inversion of an unsymmetric matrix takes longer and more memory to compute than a symmetric matrix, because we need to store the full matrix and not only the upper triangular half. Below two Ansys help theory manual links discuss this concept. (open Ansys help manual then Shift+Ctrl+D to paste this link) help/ans_thry/thy_geo2.html#geoconsistent (section : 3.3.8. Consistent Tangent Stiffness Matrix and Finite Rotation) help/ans_thry/thy_geo3.html#geopressure2 (section : 3.4.4. Pressure Load Stiffness
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- Hyperelastic Simulations
