Tagged: 18.1, General, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantIf you are using a *.db that was saved prior to solving, it will not have duplicate sector info in it. So if you are not doing the post processing immediately after solving, then you need to save the db file and then resume it to do post processing. This should give you correct cyclic expansion.
