Why can’t I use the standard engineering stress-strain to true stress-strain conversion formula beyond necking and how can I deal with data beyond necking?
March 17, 2023 at 1:11 pm
Solution
ParticipantPlease see the attached document to access the solution.
1. 2057752_Solution.pdf
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
