Tagged: 17, General, mechanical-apdl, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantNo matter how many contours are specified with /CONTOUR, the actual number of contours that appear depends also on the device option set by the /SHOW command. The X11 and WIN32 devices only support 9 contours. For more than 9 contours, make sure you set your default device option to X11C if you are on a UNIX based system or WIN32C if you are running on Windows. You can set these defaults in your startXX.ans file via: /SHOW,X11C /CONTOUR,,100 or /SHOW,WIN32C /CONTOUR,,100
