Tagged: 19.1, FE Modeler, General, Import/Export, mechanical-apdl, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantFiniteElementModeler can’t be supported from v191 version, but you can use external model to achieve this.
