June 5, 2023 at 7:04 am
FAQParticipantPrior to 14.0, the expansion of the mode-sup transient solution recovers only the static component of the nodal forces. The unbalanced nodal forces you see would be balanced by the inertia forces. At 14.0 MODOPT,,,,YES,,MSUPKey=YES is required to get the damping and inertia forces.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to combine results of static structural analysis and harmonic analysis ?
