Tagged: 17.2, apdl, General, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics, thermal
June 5, 2023 at 7:04 am
FAQParticipantSOLID185 needs enhanced strain for this application. Set KEYO,,2,2.
