Tagged: 16.2, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantOn large models, load case combination cannot be done in memory and generate IO to file.page. Some ways to reduce this are the following: 1. After solution, return to ANSYS with a large -db work-space setting. This will provide more space for the combinations to be done in memory. 2. Use INRES to limit the results being post-processed. 3. Use SUBSET to reduce the model entities being post-processed.
