January 25, 2023 at 7:34 am
FAQParticipantYou need to define the negative fluid volume. (Structural Analysis Guide Section 18.4: Example model using hydrostatic fluid elements) Otherwise the fluid volume that is attached to the piston wall doesn’t change since it is attached to the non-moving mesh of the cylinder. A good convergence norm for this analysis is HDSP. Note that the volume of a cone is 1/3rd the volume of a cylinder of the same height and diameter so the conical fluid volume defined by the piston surface (which is moving) was 1/3rd the total and produced a force 1/3rd of the expected value.
