While solving the harmonic acoustic wave propagation in a pipe in time domain and see if that matches with the one in frequency domain, is one cycle sufficient?
Tagged: 19.2, acoustics, harmonic, mechanical, structural-mechanics, transient
April 5, 2023 at 2:32 pm
FAQParticipantNo, one would need to solve several cycles to get a steady-state result within a transient solution, and this only works if the excitation is a specific frequency.
