March 17, 2023 at 9:00 am
FAQParticipantThese commands can be used to eliminate stubborn hourglassing problems: edmp,hgls,1,5 edmp,hgls,2,5 edmp,hgls,3,5 These viscous hourglass control options were the “silver bullet” in one case where they eliminated the hourglassing. So, the Flanagan-Belytschko stiffness form with exact volume integration with default coefficient (0.1) appear to be the settings necessary.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
