Which analysis system should I use, Explicit Dynamics or Transient Dynamics if I want to reduce the running time?
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attached file for more details of the solution
1. 2054219 – Transient Structural vs Explicit Dynamics Analysis.pdf
2. 2054219.zip
